Turns on SNMP trap support.
Enabled.
An authorized trap receiver can be one or more network management stations on your network. The switch sends SNMP traps to all trap receivers.
To view if SNMP traps are being sent from the switch, use the show management command. The show management command displays information about the switch including the enabled/disabled state of SNMP traps being sent.
The following command enables SNMP trap support on the switch:
enable snmp traps
